Transmission guys! I need your help ASAP!!!!
If anyone who has ANY experiance with rebuilding more then a few transmissions, please fill out this 16 question survey. It's for my senior project. I have to have it done by 3 days ago.
I've tried calling several transmission shops, and no one "feels" like helping me out. So this is my last chance at hope.... Please include the time it took you to fill this out, and please send me your name in a PM... SO PLEASE PLEASE PLEASE!!! HELP ME OUT!!!! I'll be in your debt forever if you do. -nick 1) What kind of transmissions have you built? 2) Do you understand the way a transmission operates? 3) What made you want to start rebuilding transmissions? 4) What is a cause that makes a transmission "slip"? 5) What do you think is most challenging in these Mopar transmissions? 6) When you first started out, did you find them complicated or complex? 7) Have you ever had, or seen a front drum explode? 8) How complicated would you say a Valvebody is? 9) What would you say is most challenging in the newer transmissions in cars these days? 10) Would you say a converter can cause a transmission failure? If yes, why? 11) How does a clutch operate? 12) Can you shift a manual transmission without a clutch? 13) How many gears are in a OD transmission? 14) What is a counter shaft? 15) What is a half shaft? 16) What would you say is a typical reason as to why an automatic AND manual transmission fails? |
Nick, I wish you luck with this. I got to 14 and 15 and drew a blank but had no problem with the rest. I'll fill out what I can for ya.
Here is an idea. If EVERYONE who knows trannies pitches in, then there is no reason why you can't have this done but the end of today. |
