Trying to find the right Motor Mounts!!
hey i have a 71 roadrunner, i have a 440 engine that came out of a 76 chrysler beechcraft RV. the 440 engine mounts out of the RV are way different, i know they have to be perfect, cuz if not everything wont line up right!!, so im trying to find the right ones. someone told me any 440 mounts would work...but im not sure....
you should be able to go to any parts store and tell them you want mounts for a 71 RR and they should have them :D
as in maybe NAPA? ask for 440 mounts for a 71, itll fit a 76 block? im guessing there is no difference,
as far as i no they will but where is doc when ya' need him he drives a motorhome :) anyway just look at them and make sure you have the same bolting detail on the frame and motor and if they do they should fit
lol ok thanks ill see if i can catch doc sometime...
Fabricate your own mounts! If you have a welder
.....n.a.p.a..... not a part available
on your mounts youll need to either fab them as mix stated or go to a swap meet or shcumacher ind( i think thats spelled right ) they should have your mounts at a decent price ,..... napa should be able to get you the rubber biscuit mounts that attaches to them |
Go to www.engine-swaps.com and they should have what you are looking for k
Napa is a good place to check. And those RV mounts are not even close !!:eek:
| All times are GMT -7. The time now is 11:11 PM. |
