Mopar Forums (/forums/)
-   -   Water Pump Leakage (Volare) (https://moparforums.com/forums/f7/water-pump-leakage-volare-5019/)
Johnny677 Dec 30, 2009 06:10 PM
I installed a new water pump on my volare and it leaks from the top when coolant is added. it has a metal gasket and two paper gaskets. Does anybody know what the correct way to place them when installing the pump?
Thanks
theomahamoparguy Dec 30, 2009 11:55 PM
obviously the plate is "sandwiched" between the gaskets. Is this a slant six?
johnthegoalie Dec 31, 2009 12:02 AM
mmmmm, sandwiches
https://upload.wikimedia.org/wikiped...mpson_2006.png
theomahamoparguy Dec 31, 2009 12:15 AM
I might be confused now. I dont remember two gaskets on th slant or a plate. But, it has bee a while since i've done one. some one help me, I'm out to the kitchen to make a gasket sandwich with mayo and pickles. Might cut it on a slant too, just to be different. (hehehe) [I like the donut burgers personally]
bob68fury Jan 6, 2010 12:30 AM
I have a slant 6 and i replaced the water pump recently. If i recall right its paper metal paper. What i did was butter (like if you were to butter a sandwich he he) the gasket that goes against the block with gasket silicone then installed. Your problem might be the bolts,did you install them in the exact same spot where they came from? (very important)
johnthegoalie Jan 6, 2010 01:30 AM
mmmm butter....
