Water pumps and rad
Old Feb 21, 2013 | 05:32 AM
69Ronrunner's Avatar
Water pumps and rad
I understand that they used diffrent radiators for diffrent applications, but what about water pumps? Everywhere i look a 1969 383 should have a drivers side outlet and i have mine on the passenger side which is making finding a replacement factory radiator a pain. so far i know the radiator is a 22in core with lil off center fill, top on passenger side off center, and bottom on passenger side with trans cooler. Any ideas:banghead:
did i mentoin i do have power steering
Old Feb 21, 2013 | 06:11 AM
Archer's Avatar
69 -
If you're a looking for a resto piece, you may ave to go nuts finding one or mix/match tanks and core.
If you're building a rod, then just have an aluminum radiator made to your specs. I have the same configuration that you do, and just went with a Griffin radiator. Pricy, but "cool".
Old Feb 21, 2013 | 01:10 PM
If it will fit I would get a 26" rad. 22" is barley up to the job for a HotRod . Try looking for one for a 70-71 Later style had passenger side lower outlet
Old Feb 21, 2013 | 06:55 PM
Dont u have to change support?
Old Feb 21, 2013 | 07:19 PM
moparted's Avatar
u dont have a 1969 passenger car water pump housing.
71beeper
Jul 2, 2014 05:53 PM
moe7404
May 7, 2014 11:36 AM
power wagon
Jul 27, 2013 07:42 PM
buicker
Jul 2, 2011 12:45 AM
mikeynags
Aug 9, 2009 03:52 PM
