Mopar Forums (/forums/)
-   -   What To Check On 2010 Ram 3500 Exiting MOPAR Warranty? (https://moparforums.com/forums/f7/what-check-2010-ram-3500-exiting-mopar-warranty-22642/)
TheCarsForever Sep 9, 2019 09:56 AM
Hello,
I have a 2010 Ram 3500 Crew Cab Laramie Long Bed 6.7L Diesel that is coming up on 180,000 miles. I have an extended MOPAR warranty which will be running out at 181,000 and don't believe I will be able to get a new warranty due to the mileage. While this has been a pretty solid truck, I have had a number of issues as it has aged so am a little concerned about running into a major, very expensive, issue shortly after the warranty expires. I am hoping folks here can offer suggestions of things I should be sure to check before the expiration so I can be moderately comfortable this truck will keep working for at least a little longer. If you need any additional info from me do not hesitate to let me know.
Thanks in advance!
Chris
RacerHog Sep 9, 2019 10:53 AM
Call and see if you can get the extended warranty. If not, you can buy supplemental repair coverage from another source.
TheCarsForever Sep 9, 2019 11:15 AM
Quote:
I appreciate the thought and I am looking to see if I can get an extended MOPAR warranty. I really wish I had know about the lifetime MOPAR warranty when I bought the truck as I would definitely have bought it. When I bought this warranty at 100,000 it was tough to find anyone willing to sell me a warranty - at least one without some really heavy restrictions and/or extremely expensive. Due to this I am doubtful I can find a warranty for a truck getting close to 200K.
I know there are often things not obvious until you look close or open some parts up and am hopeful I can give a little direction to look at these. Even if I get a new warranty, it would be to my advantage to be aware of any upcoming likely issues.
RacerHog Sep 11, 2019 02:15 PM
Well, Good Luck with it. If you don't find one, best advice I can say is put the Vehicle payment in a account with your bank and use that card only for your automobile repairs. :)
