Mopar Forums (/forums/)
-   -   what is the cross symbol stamped next to 413 on my block (https://moparforums.com/forums/f7/what-cross-symbol-stamped-next-413-my-block-329/)
poolinstaller Sep 12, 2007 11:26 AM
I recently was given a great running engine..I cleaned off the block (Its blue..) and on the flat plate on the drivers side behind the water pump is stammped HT 413 + (the + looking like a cross symbol)..any idea what this means and what is the HT stand for?
polyhead_318 Oct 24, 2007 05:23 PM
i remember looking that stuff up recently for my small block. a maltese cross meant oversized lifters or something. just web search casting numbers and engine i.d. codes/bosses and you should come up with meanings. hc was used to identify high compression, hp = high performance. i've never encountered "ht."
for 65 engines:
http://www.1962to1965mopar.ornocar.o...ification.html
hope that helps
vt-440 Oct 27, 2007 07:34 AM
http://www.moparts.com/Tech/Archive/motor/36.html
Maltese Cross- .001" under bearing shells
Maltese Cross & 'X'- .010" undersize crank journals
Hope this got to you in time!
Cheers:cool:
