03 Ram truck 2500 , exhaust manifold opinions plz
I recently purchased a 03 ram truck 2500. 5.7 liter. The exhaust manifolds are in bad shape. One side has a small leak due to two of the studs rusted off. I am wondering if I should just repair the studs and fix what's there or replace it all now with new manifolds or headers. I am planning on keeping the truck and don't want future problems. My other ram never had any issues like this. Any advice is welcome. Any price is a factor.
I too own the same model truck and I am on my third set of manifolds and the truck only has 40,000 miles on it. I went to headers ceramic coated stainless steel they bolted right in and increased by 2-3 mpg. and gave me a noticable power increase. If you remove the inner fenders it is an easy fix. Note: helicoil all your bolt holes as the bolt screw into raw aluminium. I used stainless steel. Gibson headers is what I used and am very pleased with there performance. Good luck its a piece of cake on a lift. Ive done tons of them in the dealership, manifolds are cheap but junk.
thanks for your advice
I priced out manifolds versus headers. I dont want to do this twice. Looks like I am about 400 bucks to replace with new manifolds, studs and gaskets. Gibson SS, CC headers run about 500 plus new studs. I have never replaced manifolds before but am not scared to try, but is this a project for a skilled auto mechanic? I restore old tractors and do most of my own auto mantienence, brakes, oil changes, alternators, but I consider this easy stuff. I have no problems stepping back if I should let an expierienced mechanic tackle this. I want it done right.
I am in a rust area, Michigan. The truck is in excellent condition other than the manifolds. They get all the crap from the front tires. I have been thinking of a way to possibly seal off the engine compartment using the inner fender and close the gaps to the engine compartment. But thats later on.
I used an angle drill with left handed drill bits. If the bolt is rusted to a point grind it flat to have a better surface to center punch on. Alot of times if you drill with a 1/8 drill bit for the pilot hole and step it up to 1/4" and give it a quick push so it bites in. The bolt will back out with the drill. I also used SS bolts and heilicoils, Its been 3 years maybe 4 since I did mine and they show no signs of rust at all. Good luck... take your time and think it through you'll be fine...Bill
I found a right angle drill that will fit and cut the drill bit down so i could drill the studs. All three have pilot holes through them and one came out with an easy out. I am glad the ones that were broke were in the back. This is taking longer than I had anticipated and the 90 plus degrees isn't helping my patience. I do appreciate all your advice, and yes the inner fenders are out.
Yes heat can make it harder on you no doubt..If your doing this in your driveway on jackstands I can surely feel your pain... I was doing it on a lift in my air conditioned home shop( one of the best things I ever built )I would be lost without it. And it is not my daily driver so I could walk away when mad. At the dealership it wasnt that easy to walk away I just sucked it up and plowed through. It also helps to have alot of tools to make the job alot easier... Sorry your having such a bear of a time with it...Hang in there you'll get it..Bill
My project is finished, although I was reluctant to do this because I thought I wouldn't have the right equipment. Thanks for your encouragement Bill!
). It is possible to do without taking the heads off but some specialty tools for the average Joe will be required. I got lucky that the only bolts were in the rear of the head, I don't know of any drill that could get to certain studs. I am pleased with the Gibson headers and the fit and finish of the kit. If you didn't have broken studs I could see this done in a few hours. Overall , I am glad I did it myself, saved a ton of green, and learned a lot. I decided to leave the stock muffler and am adding a cold air intake. ( basically a less restrictive filter). Just looking for better fuel mileage. Thx again Bill!
Brian, your welcome... when the time comes to replace the exhaust, ...I went with Banks they offer a lifetime warranty and the sound is strong sounding. It also woke the truck up and increased the fuel mileage by a couple of miles per gallon. As you know these trucks suck for fuel economy but they all do...Bill
parrothead6970
Feb 17, 2011 07:14 AM
gary2010
Jan 14, 2010 08:26 PM
