Mopar Forums (/forums/)
-   -   1954 Plymouth Belvedere carb rebuild (https://moparforums.com/forums/f81/1954-plymouth-belvedere-carb-rebuild-18547/)
Belvederejeff Apr 23, 2015 08:06 PM
Just got the carburetor rebuilt and what a difference! The engine is the 230 ci flat head six with automatic transmission. I used to say the car would do 0 - 60 mph in about five minutes. Now it has some git up and go. It also shifts from first to second a lot smoother. The accelerator pump was pretty well shot and a small pin in the automatic choke had fallen out. There was a lot of gunk in the bowl of the carburetor.Car is running great now. :hello:
moe7404 Apr 24, 2015 02:27 PM
i had a 1957 dodge puck up with an engine like that one. i built a carb adapter and put a Carter WDG 2bbl on it. all most like adding an other engine.. an old roundy round racer showed me how to make the adapter. the Carter 2 BBL was off a Kaser . that was a Continental Red Seal engine.
RacerHog Apr 24, 2015 03:02 PM
Glad you got that 54 Running good !!!!!!!!
