1966 Chrysler 440 rough idle probs
Hi guys, any info is greatly appreciated. Just swapped a rebuilt 1407 edelbrock carb on my rebuilt but (factory specs) 66 Chrysler 440 with stock iron 4 hole intake. Can't seem to tune the shake out at idle. Also below 1500 rpms the engine seems to surge slightly on the tach in a no load situation. Engine runs great otherwise, pulls hard from a dead stop through the gears with no hesitation. Checked timing over and over again. Makes 14" vacumn at idle but when the engine has a hick up or shake ideling the vacumn gauge bounced around at same time. Only noticed this prob after removing the original carter afb carb. 440 ran smooth as glass with the carter, just took it off because it looked worn and unknown age of rebuild. 1431 carter 575 cfm rating. The 1407 edelbrock really woke up performance all around. I had a 1" spacer open style under the edelbrock when first installed but I removed because the carb company said the open style spacer would cause turbulence with the 4 hole intake. After I removed and put carb right on the intake it did smooth out the idle some but still nowhere as smooth as the carter was. I did also swap a mopar electronic ignition in at same time with orange box when I did carb. Had timing at 35, 36, 37, and 38 deg total advance and the more t retarded timing the worse the stumble became. Engine runs best at 38 total coming in at about 2400 rpms. No pinging what so ever and runs cool all day. Thanks, I hope I gave enough info Tim
Re Check it for vacuum leaks..... The lower vacuum kind of bothers me...
But for the most part. I would say it's overly lean at idle being the problem. Just my 2 cents. |
(Post 139636)
Take the screws out 4 turns and see if it smooths out...
Not to sure where your taking the vacuum read... But unplug the PCV hose and check it at that port and see if the vacuum is better there.... I'm not sure if your fighting a larger cam or maybe late timing or possibly a mechanical issue to give you the low vacuum...????? Will keep hunting it with you... :) |
(Post 139643)
(Post 139643)
Ok... Humm... Ok on the Idle air mixture screws.... Will revisit those later.. :)
Double check the wiring for the new Dist. Sometime the wires get crossed with the two coming out of the Dist. and it will cause the engine to run funny. Normally this only effect the upper part of the RPM, But you never know. Also, Just try the old Cater first and see if that fix's the problem and then if that dose not.. Then try going back to the points.... Let see if you can find out just what one is causing the problem. What I'm saying is... It might be one or the other, and you will not know by doing both at the same time. Keep us posted.... :) |
(Post 139656)
Look down the carb when its running and see if it is pulling fuel from the ventures at Idle?
Also look to see if the carb primary plates are in the transfer slot or are actually down working off the Idle Circuit? Might have to take the carb off and turn it upside down to tell. Plugs should not have been black.... The stumble might be a accelerator pump adjustment. But I don't think I would touch it until some of this other stuff gets sorted out. What I'm looking for is some of these carbs come with the Float level way out of whack.. Might give that a check over. Some times to high. |
