1975 Cordoba 360 Build Tips
New To The Mopar World But Not Engine Builds
Looking For Some Info On Good Set-up For A Street/Strip 360 Engine Low Mileage, None Smoking Engine Looking For Cam Picks/Intakes Other Stuff Any Ideas |
Cordoba is a heavy car ! You probably have a thermoquad carb ? If it is working it is fine. With stock gearing 2.91- 3.21 ? Just a good set of dual exhaust Very mild cam will help . IF you are going to put 3.91 gears or ? that will change everything
looking at keeping the rear gear as it stands for now
any part #s for a good cam kit? |
how about this: Summit racing Part #SUM-K50052.
...summit cams kits are actually very good quality, made for them by melling, and you cant beat the price $145 for the cam and lifter kit. This cam is .454 lift. this would give the Cordoba plenty of grunt and some top end. |
With The Duration 272/272, Lift .454/.454 We I Run Into Other Problems Down The Road? Or Needed Mods?
Anyone Using This Cam? Was Looking At The Edelbrock 2177 - Edelbrock Performer-Plus Camshaft Kit |
I think you would get by with some new springs. Should have no problems with coil bind or piston to vavle. stock 360 pistons were down in the hole If you were worried just drop down to the next size smaller. I think it is a .440 lift. thats what I got in my "truck" motor.
