1bbl Holley carburetor to 4bbl Holley
I have a 1966 Dodge Dart GT with the 225 slat 6. I want to go from a 1bbl Holley carburetor to a 4bbl Holley carburetor other than the intake manifold and carburetor what else do I need to do so that the engine runs good? Example: Do I need to advance timing, adjust fuel pedal, or will this be a swap and go. Thank you for any responses. Just to avoid confusion the intake manifold I want to go with is a offenhouser 4bbl. Summit website suggests a 390 Holley.
Welcome.
That much carb increase should have a camshaft upgrade. |
(Post 145315)
Welcome.
More compression, head work with new valves, springs etc. port work , performance cam and dont forget a set of headers and new exhaust. That new carb just got expensive but if you don't the rest you don't need the carb.
(Post 145319)
More compression, head work with new valves, springs etc. port work , performance cam and dont forget a set of headers and new exhaust. That new carb just got expensive but if you do the rest you don't need the carb.
Have a look at this: https://www.allpar.com/mopar/hyper-pak.html
(Post 145323)
Originally Posted by Donovan
(Post 145322)
After much consideration I think I'm going to get a 2bbl intake and carburetor. I know that will be a lot less work.
(Post 145326)
Chrysler offered a two barrel carb in the seventies I think it was called the super six. But stock parts are our there for this upgrade.
Why not get the 4 barrel and 2 barrel adapter so your ready when you want to rebuild and really hot rod it?
(Post 145330)
