Mopar Forums (/forums/)
-   -   318 overheating (https://moparforums.com/forums/f81/318-overheating-20328/)
aaron206 May 15, 2017 07:31 PM
318 overheating
I know this has come up before, but maybe there are some new genius' on here that can help me from loosing so much hair so fast. I have a 69 charger with a 318 that won't stay cool. I have:
replaced the thermostat after checking it to make sure it opens at 180 degrees.
drilled a hole in the flange of the thermostat
Replaced the sensor in the block.
removed and cleaned out the radiator
but it still climbs to 270 (thats as high as the stock gauge goes) in about 10 minutes even on the highway. But when I stop its not puking coolent or steaming like I would imagine it would at 270. Could the gauge be bad? It just started doing this this month. The only thing I haven't done is get a shroud. Would a shroud make that much difference? Any help would be awesome. Thanks.
Iowan May 15, 2017 08:11 PM
Have you checked to see if you have compression coming in the radiator, I would be looking at the head gaskets.
TVLynn May 15, 2017 10:19 PM
Have you checked the water pump impeller ? Maybe rusted away or broken
aaron206 May 16, 2017 02:05 AM
How would I check for compression in the radiator? And I thought the water pump leaks a bit if its broken?
Archer May 16, 2017 07:15 AM
arron -
Basic rule, do the easiest thing first, even if it has a low yield.
Check the gauge first, just borrow or buy an cheap Sun gauge from Advance or any parts store and hook it up to a different port.
An IR thermometer isn't expensive (around $30) and can help finding hit spots and has a lot of other uses.
Iowan May 16, 2017 09:54 AM
Remove the rad cap start the thing up and see if there is a large amount of air in the coolant. Check the coolant and see if its moving.
As far as the water pump goes the impellers rust and has nothing to do with the seal.
aaron206 May 16, 2017 04:03 PM
well its not the water pump. Just pulled it since I already had the fan off and radiator out. It 's fine. No bubbles in the coolant either. I checked before i pulled the rad to clean it. So I guess Ill put it all back together and see if its the temp gauge.
Iowan May 17, 2017 01:14 PM
Still say head gaskets.:)............
Been there done that.........
Iowan May 17, 2017 01:23 PM
One change, if it's getting to 270, cracked heads or block very possible.
aaron206 May 18, 2017 01:46 AM
If it was a head gasket or cracked head wouldn't I get white "steam" from the exhaust and a noticeable loss of coolant? I have had a blown head gasket and a cracked head on another car and it poured white exhaust.
RacerHog May 18, 2017 05:49 AM
My question would be..... Is it overheating or is the gauge bad? What are you trying to fix? Overheating or electrical issues?
Iowan May 18, 2017 06:13 AM
I misread the first post and agree with Bob, I wouldn't trust the old gauge. A simple fix would be an aftermarket gauge. Factory gauge wasn't reliably accurate when new.
aaron206 May 19, 2017 08:49 PM
Well got it solved. It was a bad gauge. I installed a new temp gauge (in a different port so I could get both reading at the same time) and the stock gauge was pegged at 270 and the new one read 190 with a 180 degree thermostat. On the up side I now have a new thermostat, water pump gasket, temp sending unit, a clean radiator, a flushed engine and now know much more about my cooling system. All's well that ends well! Thanks for you input everyone! On to the next thing, Disk brake conversion.
RacerHog May 19, 2017 09:30 PM
Good Deal..... You still might look into a fan shroud when you get a chance...
Glad it was a simple fix... :)
Coronet 500 May 20, 2017 06:03 AM
Now you have it running properly take some infrared gun temps with engine running of the thermostat housing and rad hoses. Record the information to compare in the future if you have a suspected problem in the future.
