Mopar Forums (/forums/)
-   -   318 Question (https://moparforums.com/forums/f81/318-question-11263/)
cinciaz Dec 17, 2011 08:37 PM
318 Question
Hi all, im new and hope im in the right forum.... I have a 1972 318 LA engine. Under the numbers that are on the front of the engine are the letters "RB", they are vertical. Does anyone have any idea what this can mean? The engine is in a 1973 Dart Sport that was formally an undercover police car back in the 70's.
78doubleR Dec 17, 2011 09:42 PM
Raised block, but i didnt think they made rb 318s, just big blocks. let someone else chime in.
cinciaz Dec 18, 2011 11:02 AM
1 Attachment(s)
Its BR not RB. Ill try to post a picAttachment 4959
440roadrunner Dec 18, 2011 11:47 AM
That's not "BR", it's 318R and unless the block is some oddity, or has been rebuilt by someone who obliterated that number string, every small block has the CID as that one does, IE 273/318/340/360
(I have a Mopar rebuilt, 040 360 which had that number obliterated, and a glue on!! sticker replaced it)
cinciaz Dec 18, 2011 12:02 PM
Im am talking abount the RB stamped below the M318R. Click on the pic it to enlarge it
Coronet 500 Dec 18, 2011 06:51 PM
Here is some stamping info:http://www.yearone.com/updatedsingle...gnumbers4.html
Nothing I have seen in a stock block like this, sometimes a machine shop will stamp an identifier if work has been done or a warranty repair.
78doubleR Dec 18, 2011 08:28 PM
I've already looked through this.... nothin.
bremereric Dec 18, 2011 09:32 PM
I will take a guess that it is a replacement block....BR backwards.
78doubleR Dec 18, 2011 10:17 PM
You might be onto something Eric. It could be anything since its a stamp and not part of the casting like the date codes would be.
cinciaz Dec 19, 2011 11:54 AM
Thanks for all the input people, if it is a replacement block from the factory would there be numbers down by the oil pan where the ID numbers should be? The numbers I have on the ID plate are 2R3555 8. There is no number between the 5 and 8. Thanks again people for all your help.
