318 Rods
Friend of mine cracked his block, so I helped tear down his block to the bare block to see if anything else went bad.
Decided to take the pistons off the rods at my shop class, and junk the pistons. I'm considering having a shop just crack check and measure the con. rod bores for roundness. These came off a '99 dodge ram 1500 LA block. Would they be worth checking out and possibly reconditioning and trying to re-sell? I would also be doing ARP rod bolts if I commit. |
NOT worth the effort
Originally Posted by TVLynn
(Post 125225)
Guess I'll just use them for balancing practice on a grinder belt and just keep one for a standard if I get snap gauges. |
These are the things you might want to keep if you stick to small blocks, when you need one or a set it's nice to know you just have to go down to the basement.
| All times are GMT -7. The time now is 07:41 AM. |
