318 timing set q
Old Dec 18, 2018 | 05:02 AM
1978W150's Avatar
318 timing set q
I have a 1978 dodge ram 5.2 that I am putting 1985 5.2 motor in, while adding the fuel pump cam I noticed the timing chain had about ½+ inch slack in it, so I ordered a new set and wouldn’t ya know it also has about a ½ inch slack in it. it was ordered on line (cloyes). Is this normal or should it be tight?
Old Dec 18, 2018 | 08:27 AM
I've seen motors that have been line bored have slack in new timing chains, not sure what you can do about it.
Old Dec 18, 2018 | 03:13 PM
It should be tight, Cloyes catalog says center dimension is 6.125", adding -5 to P/N is .005" shorter, -10 is .010" shorter.
Was this ordered on line from Cloyes or someone on line selling Cloyes 2nds? Hopefully you have recourse.
Old Dec 20, 2018 | 08:13 AM
See if one of these will help your problem...… http://www.moparonlineperformance.co...p/p5007709.htm
Sam84218
Oct 31, 2019 06:53 PM
Panderz
Mar 14, 2016 10:27 AM
mrzods13
Apr 17, 2014 09:45 AM
dynahd
Aug 8, 2011 03:26 PM
fastdakota84
Jan 28, 2011 06:41 AM
