Mopar Forums (/forums/)
-   -   340 intake swap (https://moparforums.com/forums/f81/340-intake-swap-12723/)
twisted68 Jul 5, 2012 05:33 AM
340 intake swap
Great fireworks last night! Hope everyone got home safe. On to my questions. Will a stock cast iron intake from a '73 340 cause any problems on my '69 340? Also, I just received a Torker II and am trying to decide what kind of performance/driveability I want. The engine is a '69 340,.060 over, worked x heads, purple shaft cam, flat top pistons, headers, etc. in a '68 Coronet 500 convertible. Automatic w/ 3.55 rear end. Thank you in advance for your thoughts on this.
78D200 Jul 5, 2012 06:57 AM
Yes you should be able to swap the cast iron intake between the two motors. With how you have the motor built, I would sugest going with the Torker II intake but that also depends heavily on how you plan on driving the vehicle.
440roadrunner Jul 5, 2012 11:23 AM
I'm not sure that a Torker II would be a good combo in that heavy car. These manifolds were not "named" correctly as they most certainly are NOT a "torque" manifold. I believe the factory manifold would have more bottom end and mid range for a heavy car
Incidently, I "did" this a very long time ago. My favorite car I ever owned was a 70 sixpack RR, but in the "first" gas crunch of the early '70's I swapped a low miles 340 into the car. This was a stock 71 high compression 340, with headers, and with the 3.54, 4 speed and "hang on" aftermarket A/C that engine gave me better than 17 mpg. In my opinion, Ma really screwed up by not developing the 340 into a broader base. The 340/ B body combo would have competed very favorably against a SB 327/350 Chevelle, for example.
The sordid story:
https://moparforums.com/forums/f62/m...-back-day-596/
bremereric Jul 5, 2012 12:48 PM
I would go with a small block RPM Performer from Eddy.
twisted68 Jul 5, 2012 12:58 PM
340 intake
Thanks again to both of you. Don't plan on street racing anymore but still would like to get going when I push the fun pedal. The exhaust system runs through glasspacks into Hemi resonator mufflers into Mopar tips. Sounds very good. Used to run an Offy dual plane w/ 2-4s but hard to keep tuned and VERY hard on fuel. Guess I'll hang on to the Torker for now. Next question is carb. Don't think I need more than the AVS I have.
twisted68 Jul 5, 2012 01:05 PM
340 intake
Sorry missed about the RPM. My research on this site and some other Mopar sites is that I should keep my money for other things as my cast intake performs pretty well for an old dog. Ma Mopar knew what she was doing!
78D200 Jul 6, 2012 02:47 AM
With what you discribed, I'd go with the stock intake as well. The Torker II (made by Edlebrock IIRC) is a mid to high range RPM intake and really only good for those to race the vehicles down the strip.
As far as a carb goes, I'd look at ~650cfm carb with a fat fuel line.
twisted68 Jul 6, 2012 12:38 PM
340 intake
I have a Carter AVS I rebuilt last year. From what I learned it's the carb I need. Fat fuel line makes sense. Thanks. Just need to get the elec. system sorted out as to why it won't fire. Heading out into the heat now to start troubleshooting.
