360 head question
360 head question
i am rebuilding a 360 and the heads i took off the motor had different casting numbers. one 3769974 the other 3671587-4. i know the valves are the same. this motor has ran before but are there any major problems with new mods(.040 over, cam, higher compression piston)?
your heads are the same valves the first is 75-76 yr and the later is 76 yr most likely the vehicle was assembled at the factory with the heads maybe they where running low it's not a big deal for the factory, or the heads where re-manufacturer and one was replaced.
have your machine shop double check to make sure one wasn't modded
so i got the heads back and i need to get new valve springs. i cant find specs on a stock replacement. not sure of what to get. cam is a 278/288, Lift .421/.444... not going to be a high reving engine.
I use this one with the 901 springs, retainers and locks recommended in the truck and very happy.
http://www.compcams.com/Company/CC/c...?csid=625&sb=2
send it back your going to get lousy mileage and low power
the MP purple cam 284 dur 488 lift
the same lunati cam advertised Duration (Int/Exh): 276/284
Duration @ .050 (Int/Exh): 234/242
Gross Valve Lift (Int/Exh): .513/.533
LSA/ICL: 110/106
hell even my cam with shorter duration has a higher lift
if you haven't installed it return it summit is great
and get a kit
LSA/ICL: 110/106
and get a kit
Dominic Torreto
Oct 11, 2012 09:10 AM
