360 SB mopar distributor for MSD wires
I changed my new HEI type distributor for my old and tired stock mopar one and my 74 Fury now runs a lot better, but, this distributor has the vacuum advance broken, has never been rebuild and I want to use the MSD wires I bought for the HEI type distributor.
I checked on Rockauto but looks like the mopar distributors they sell only have female type cap and the MSD wired needs male type cap What should I do? I want to run my MSD wires and a high voltage coil I need this type of cap https://e6416a4cab428d4fa6c5-9c73423...[x220].jpg Instead this type http://static.summitracing.com/globa...-120123_ml.jpg |
I've been useing MSD for over 25 years, so red or black? What was the question?
(Post 132180)
I'm not a fan of oem distributors for performance applications.
Took about 30 seconds on Google. "440 source" shows one, I did not look any further
http://store.440source.com/Distributors/products/62/ |
Originally Posted by DDodger
(Post 132187)
http://www.hughesengines.com/Index/products.php?browse=category&level0=QS0gU21hbGwgQm xvY2sgIkxBIg==&level1=SWduaXRpb24gJiBFbGVjdHJpY2Fs &level2=Q2FwcyAmIFJvdG9ycw==
Try this. They should have what you need. |
Originally Posted by josehf34
(Post 132285)
I'd suspect that cap is made for a big block dist, or the cap from a big block dist is the same of a small block?
j -
I may be wrong about what you're asking, but most universal wire sets have both types of cap boots. Or you could just buy an after market set of boots and use them on your new cap. Archer |
