Mopar Forums (/forums/)
-   -   383 build help!!!!! (https://moparforums.com/forums/f81/383-build-help-15349/)
maynardc69 Jul 18, 2013 06:27 PM
383 build help!!!!!
I am looking for help with building my 383. I want to use the stock block. Stock heads if possible. It's the original motor in my 1971 charger se. I want it to be when I stop at a street light it sounds like it's gonna die. That big lump sound. I don't have anything for it yet. budget build if possible. Anybody have any ideas?
moe7404 Jul 18, 2013 07:34 PM
find one of the old chrysler Direct Connection race books. and do it JUST like chrysler says , NO more , NO less. the key phrase PER CHRYSLER ONLY. if it says use a Carter carb DO it. dont for get a chrysler race car is NOT a cam and a carb. it is a SYSTEM. each chrysler race car was designed to a certen speed and just what they did. look at the 1965 300 L the last 300, it was the only 300 one a single carb. target 1/4 mile E.T. was 16.00 sec. and that is what mine did. it was NOT a full out race car. chrysler called it a gentlemans performance car.
moparted Jul 18, 2013 09:35 PM
yes,lets use 40 year old info.
RacerHog Jul 19, 2013 08:26 AM
YA.... But you got to love the sound of an "old 3/4" race cam.....:)
Coronet 500 Jul 19, 2013 01:46 PM
Have a look at the Comp Thumpr and Hughes Whiplash cams.
moe7404 Jul 19, 2013 03:33 PM
it worked then. it WILL work now. a 12.xx sec max-wedge is still 12.XX sec, or more. my point is chrysler spent tons of time making a fast car. and ill bet you cant better it. i mean YOU, NOT a cam mfg
moparted Jul 23, 2013 08:56 PM
yes lets build 15 sec car.
maynardc69 Jul 27, 2013 12:06 PM
Ill look at those cams. I am thinking of either doing a 8-71 blower or twin turbos. Any thought on either one of those?
maynardc69 Jul 31, 2013 02:28 PM
1 Attachment(s)
Thanks for the help guys but the deal fell thru. Now I got a set of long rams Im gonna sell or use. Havent decided yet.
1968newport Aug 5, 2013 08:09 AM
If your thinking of a blower motor, get ready to spend $20,000 plus for a budget. It's not just the motor you have to worry about at that point. Exhaust system, rear end, tranny, torque converter, ignition system, suspension. Low budget and blower don't go together, especially a bigger blower like the 8-71
maynardc69 Aug 7, 2013 12:25 PM
I had the idea of doing dual EZ EFI with twin turbos on these long rams, that way you wouldn't need the exhaust manifolds hooked up. But once again I changed my mind and im selling them on ebay.
If anyone is looking for them here ya go.
http://www.ebay.com/itm/300944550849...witem=&vxp=mtr
