41 plymouth timing
How do I set ignition timing on a 41 plymouth
According to my old Motor's Manual, tune up specs as follows
Spark plugs, Autolite AL-7B @ .025" gap breaker points .020" gap, 35--38 degrees dwell Timing says "DC" or "0" mark on dampener idle speed 475 RPM A photo shows the pointer should be on the timing cover almost directly above the dampener. And no.........I'm not quite THAT old!!! My Dad was, though!! |
Welcome To the Forum Duzenack.....
440roadrunner...is old:duck:..... But full of good Info... :) Post up some pictures when you get a chance..... |
Originally Posted by 440roadrunner
(Post 111247)
Thanks. Yes I am that old. I am older than this car by 1 year. My manual gives some information but it refers to #6 cylinder. Do I use #1 or #6. Can you tell me the firing order? Be thankful for Dads.
Thanks, Paul |
Firing order is 153624. All I could find in Motor's refers to no1. There are very few engines not timed off no1. IHC V8s are one, they use no8 which I've always thought was plain silly
firing order
Thanks again for the help. I am getting the engine put back together. Hope it runs.
\ \Paul |
| All times are GMT -7. The time now is 06:06 AM. |
