440 bearing question
3 Attachment(s)
Gang, I am so excited that today I finished the tear down part of my 440-:hello: I have 2 questions that I am not sure why they are this way. First the front freeze plug on both sides of my block are rubber and the others are like normal I have not seen it anywhere in what I read- does anyone know why this is??
Attachment 14914 Number 2- when taken off the main caps off the block the #3 cap bearing didn't come off like the others. Again this I haven't read about, could it be a bad bearing or something that is special for the #3. Attachment 14915 Attachment 14916 |
1st Question: those are the cheap rubber replacement ones someone installed to repair a leaking freeze plug. Get rid of it.
2nd Question: #3 main bearing is a thrust bearing. You will have to use something to knock it off or pull it off. It overlaps the sides also. |
(Post 80488)
when rebuilding replace the freeze plugs
Looks as if the #3 bearing has alot of wear, also is fully grooved. Was this a H P motor? May have a pinging problem. Calculate your compression ratio before assembly. Dont want to have more than 10.5 to 1 for the street. This may be pushin it depending on your elevation.
Originally Posted by Garys69RR
(Post 80534)
Try this one: http://www.kb-silvolite.com/calc.php?action=comp
Thanks bremereric and 500, I will get these measurments and see what I have and will get. Joe
| All times are GMT -7. The time now is 05:47 AM. |
