440 compression
Hello everybody ! In first, exuse me if I’m wrong in my sentences because I speak French. In second lets talks for real :
I have a 1970 Dodge Challenger 4 speed with a 440 Magnum, street car. The 440 engine is from 1973, Compcams camshaft Street/Strip : Duration 284/296, at @.050 240/246 http://www.compcams.com/Company/CC/c...?csid=709&sb=2 Holley Sniper EFI 800 CFM, Edelbrock Torker II intake, MSD 6AL ignition, stainless exaust. But I wan’t more compression (about, 9.7:1 / 10.8:1), cylinder heads are stocks (so 82cc if I'm good ?), I didn’t open the motor but I think pistons are stocks too, so my question is : The best way is to change pistons and cylinder heads, or just piston, or just cylinder ? If cylinder heads what do you thing about the Edelbrock E-Street cylinders heads ? (in 75cc) http://www.edelbrock.com/automotive/...treet-bb.shtml Thanks you ! |
The heads will give you the best bang for your buck, stock heads are closer to 90 cc. And will out flow your stockers.
(Post 143651)
Are 70 and 73 pistons the same ? Did I need to change the deck clearence of the piston if I change for the Edelbrock E-street ? |
What the best for my application : Edelbrock E-Street, Performer RPM, Victor ?
Looks like your looking to build something like this build? >>>>>>>> http://www.hotrod.com/articles/how-y...hp-street-440/
You might need to check and make sure the gasoline octane in France will be OK? Keep us posted.... Welcome to the site... :) |
(Post 143668)
You might need to check and make sure the gasoline octane in France will be OK? Keep us posted.... Welcome to the site... :) But did someone know the dome volume of factory pistons ? And a last thing : sorry for my knowledge but it's my first time for engine building (but don't worry I won't be alone for doing that) how did we change the deck clearance of the pistons ? Thanks |
This is done with compression height (C.H.) which is the piston pin center line to the top of the piston. When you add C.H. with connecting rod length and 1/2 of crankshaft stroke you will get close to bock height. When comparing pistons look at C.H. first and you'll get close to zero deck and get quench with closed chamber heads.
As an example most Mopar engines have the piston "in the hole" below deck, there were some 340's built with the piston above deck to raise compression with the open chamber heads they had available. When you come to piston selection you will come across some called step pistons, these have a portion of it above the deck for open chamber heads to raise compression and if fit correctly give quench. I would go with the Performer Head. |
This might also help with some under standing... Not 100% that it will cross to French? But worth a try... :)
http://www.wallaceracing.com/Calculators.htm |
RacerHog : don't worry for me, I had learn all 'mecanical' term in english, in car parts I'm better in english than french ! Lol
Coronet 500 : oki doki thanks you ! |
Originally Posted by Apewalski70
(Post 143699)
With E-Street or Performer heads did I can keep factory rocker arms and pushrod or I need something like this https://www.summitracing.com/int/par...1-16/overview/ ??
Better to change the rockers and shafts so you are able to get the rite geometry after measuring for the rite push rod length...
Just my 2 cents |
(Post 143710)
Just my 2 cents |
Problem becomes... If you don't get the rite length push rod's, the load area will get to much side load, and has a trendies to bend or burn/crack the tips off the push rods.
(Post 143714)
Just food for thought... :)
(Post 143716)
(Post 143717)
So perfect !!! Thx
Food for thought?
I agree... You have to go threw any head that you buy..
lowan / racerhog : okok I take note, didn't have a lot of money, but if I need just more time for something better I can wait and save more money.
Drag Pak : thanks you ! |
