Mopar Forums (/forums/)
-   -   440 header bolts with aluminum heads (https://moparforums.com/forums/f81/440-header-bolts-aluminum-heads-17702/)
Skynyrd Aug 19, 2014 03:36 PM
Header bolts coming loose.
Need some suggestions bolt type , locking or not.
Ceramic pro comp ,hooker headers. Maybe gasket type that works best.
They really got loose in just a few runs. Pro maxx 440 aluminum heads. These are new to me and looking for the right combination.
RacerHog Aug 19, 2014 08:14 PM
These work pretty good......
http://www.summitracing.com/parts/ph...iew/make/dodge
Might find these to use with the flat washers....
http://www.fastenersplus.com/3-8-ste...CB6RoCmx_w_wcB
However I'm a Lawson guy.... Great stuff these guys have and spec..
http://www.lawsonproducts.com/Lock-W...s/FS120060.lpc
But might be to tight for those headers?????????
Coronet 500 Aug 20, 2014 02:35 PM
My son just bought one of these type based on our Speed Shop supply guy giving up on the others and positive feed back from his customers.
http://www.proformparts.com/product-...ategory_id/320
http://shop.totallystainless.com/pro...eaderbolts.php
Sorry no personal experience yet.
moe7404 Aug 21, 2014 03:05 PM
of course we all know to NOT use cad plated bolts on the exhaust system. and DO use anti-seize compound on ext system and all other bolts on the bottom of the truck.
Skynyrd Aug 22, 2014 05:24 AM
header bolts
I installed the ss arp we had used before but with Mr gasket lock washers .
Regular felpro gaskets that matches the old ones.
Just going to watch close. Also used high heat antiseze. Thanks
If I still experience the bolts coming loose we will look at the locking bolts again.
