440 puffs out through carb and valve covers after shutdown and blows up valley pan.
Old Jul 15, 2017 | 10:13 PM
Srlawrence05's Avatar
After I am running the 440 when warm, when I got to turn it off a few seconds later it puffs kinda loud out of the carb and out the valve cover breathers? Can't figure out why.
Old Jul 16, 2017 | 05:50 AM
Archer's Avatar
Lawrence -
Ah, too much timing?
Try backing it off a bit and see what happens.
If that doesn't help, you have to start thinking valves.
Old Jul 16, 2017 | 05:56 AM
Welcome.
Is your crankcase ventilation system in place and working properly?
Check your PCV and hose for vacuum at different rpm's.
Old Jul 16, 2017 | 09:22 AM
Gorts 5th's Avatar
Smile
I agree with archer where s your timing set.
Im thinking it needs to be around 6* btdc.
Archer is that correct? On a b.b.
Old Jul 16, 2017 | 03:01 PM
Archer's Avatar
Hey Gorts, good to see you again.
Depends on the year and other stuff done to it, but a lot of mild 440s like about 10* initial and 32* total. But YMMV.
Old Jul 16, 2017 | 06:54 PM
Gorts 5th's Avatar
Smile
Thsnk you same to you archer its refreshing to be back.
Old Jul 17, 2017 | 05:35 AM
Welcome.
yea I have evac hoses hooked up to each exhaust. It's on jet boat. But I will check and see if they are working properly
Old Jul 17, 2017 | 05:36 AM
Lawrence -
i have timing set at 36* at 3000 rpm
Old Jul 17, 2017 | 05:37 AM
also has a fresh valve job done so I wouldn't think that's the problem
Old Jul 17, 2017 | 06:04 AM
Archer's Avatar
Lawrence -
No idea about about 440s on jet boats, since drive train resistance is a little different than on a car/truck.
Without a pretty decent sized cam and possibly higher than std octane fuel, 36* total may be a little too much. A new valve job unfortunately doesn't preclude a bad or sticky valve.
Bumping the advance back a few degrees is a quick and easily reversible test, so I would start there.
Old Jul 17, 2017 | 01:08 PM
At this point.... I'm going with Condensation & Vapor Mist....
Old Jul 17, 2017 | 01:29 PM
I'm thinking broken ring or piston.
Old Jul 17, 2017 | 04:29 PM
Could Be....
Old Jul 19, 2017 | 07:06 AM
Gorts 5th's Avatar
Smile
My budy had a leaking head gasket and he would find the dip stick pop off it's seat. With light oil spray about the compartment.
And i agree the timing curve is very diffent in a jet boat than a automobile.
I wonder ....the grinds are they diffent...for marine engine's?
Kip42
Feb 19, 2014 11:43 AM
mopar777
May 29, 2011 11:25 AM
samuelcosmo76
Dec 7, 2009 03:40 PM
crmzendrgone
Oct 8, 2009 01:31 PM
blue 68 gts
Mar 7, 2009 08:14 AM
