440 wants to idle at 35-40° btdc?
I just picked up a project truck with a 440 from a 1978 New Yorker. From what I have been told it's got about 5k miles, on a .20 over rebuild approx 9.5-1 compression and a mild "RV" cam, Edlebrock 750 with electronic ignition. It wasn't running the best when I got it and after cleaning up the carb it's a lot better but I'm getting readings on a timing light of around 36° at approx 850rpm (yes vacuum advance is unhooked) I've checked the balancer against TDC on cylinder #1 and the line on the balancer lines up with the little hole in the timing tab and rotor is pointing to just before #1 plug wire. It dies when I try to retard it . This thing can't really want to run at 35+ degrees of initial timing can it? What an I missing here? I'm new to Dodges but I thought timing was timing.
Something is off, check and see if #1 is infact #1.
(Post 146903)
It has a Mopar "orange" ignition box, any chance this like an MSD multispark box where you have to disconnect something to get accurate readings on a timing light?
Using the distributor to verify top dead center isn't accurate. You need to pull the plug in number 1 and find and find tdc in that hole. On a big block mopar that's the front cylinder on the drivers side.
(Post 146910)
How much advance do you have at 3500 rpm?
I don't recall exactly but I think it was in the 50's. I'll try to check again probably this weekend when it warms up a little and I can have the garage door open and not freeze or gas myself out.
Zen -
One of two things. The plug wires are shifted over one tower. (Yeah, I know you checked.) The timing chain slipped or was installed incorrectly. Archer |
Don't rely on the distributor position, buy or build a piston stop to do an accurate TDC location.
and I would say add a little more timing and see how it runs. If it runs good by ear, and you have no detonation with decent vacuum, let it idle. I have a small block .030 over with a cam, headers and DUI distributor and it likes it there too. It runs fine. maybe the cam was off a tooth or maybe the harmonic balancer is not marked just right. If it isn't detonating, and the engine runs good by ear and starts fine, call it good.
*UPDATE*
After speaking with the previous owner I learned that the gas is probably a year old and possibly 87 octane ( 10% ethanol :doh: ) After draining the tank and giving it a fresh gulp of 91 it not only runs like a new machine, it will happily let me turn the timing down to 18° @ 750rpm! I thought bad gas wanted retarded timing? I still have a little tweaking to do but there is hope in sight. I also learned that it's near impossible to do a W.O.T. test on 440 in an empty 1/2 ton pickup truck :devil: Is 18°@750 (with no vac advance) a good starting place, or should I be more concerned about total timing at a higher (?) RPM? |
Total mechanical advance should be less than 38 degrees.
| All times are GMT -7. The time now is 05:37 AM. |
