Mopar Forums (/forums/)
-   -   451 stroker valve lash (https://moparforums.com/forums/f81/451-stroker-valve-lash-19148/)
tcgrump Jan 31, 2016 09:53 AM
Hi guys, don't know what cam is in 451 stroker in 69 Fish I just bought.
Where is a good place to start valve lash- solid lifters. Car is giving me fits with spitting through carb- have tried advancing to no avail. New plugs, wires, distributor, cap, rotor, (electronic ign) no vacuum leaks-Holley 750. Firing order confirmed. Ran car gently through neighborhood then it developed a cough on number 2. Valves and springs good all rockers working. Lash is currently at .018/ .022. seems to be spitting on all cylinders now and not just #2.
Thanks a bunch
TC
RacerHog Jan 31, 2016 10:38 AM
Hard to tell with out knowing what the cam grinder wants.... How did you come up with the 18/22...
Here is what Comp Cam said... Just the one I looked up.??????
http://www.compcams.com/Company/CC/c...?csid=738&sb=0
Check and make sure the Dist. Shaft is not bent.... :)
Also Recheck the compression in all cylinders....
tcgrump Jan 31, 2016 12:09 PM
valve lash
Thanks Bob,
18/22 was consensus #s from other hot rodders, engine builders, etc.
I'll work on car a little more later this week and repost- thanks.
TC
Drag Pak Jan 31, 2016 12:15 PM
What cylinder heads are on it?
TVLynn Feb 4, 2016 01:20 PM
Sounds good for aluminum heads
