452 heads
I have a stock 440 and 2 452 heads. One is in the motor and an extra set that has been ported but don't know anything about it. I have been taking the valves out to get them cleaned and shaved possibly but some of the valves are stuck. Any ideas how to get them out
Bump
Long drift punch... Beat them out and throw them in the trash...
Sound like someone set the heads up wrong on the first go round.. That just my 2 cents.... |
What about them being an open chamber? Are they worth my time?
452 Is a good Head..... But I read your going to boost it!!! Use the preditor head.... Or even a set of Victor's would be good....
If the valve stem tips are mushroomed, you may wish to file/grind the tips before removing the valves to prevent cracking the valve guide bosses during removal of the valves.
(Post 125445)
I'm not familar with the predator head. Who makes them? My idea was to hand port my 452 and then when I finish building my other block I would use aluminium heads when I boost. |
Originally Posted by Drag Pak
(Post 125456)
(Post 125445)
yes... Not sure you need that much of a Cylinder head. But something to throw around.... You might even try B1 Heads... If it fits the program a little better... Just food for thought..:)
(Post 125490)
I'm assuming for both but not sure |
Your 452 heads are a good and desirable part in the Mopar world.
There are Step Pistons available to raise compression with open chamber heads. https://www.uempistons.com/index.php...a00126b87fac92 Merry Christmas, Dan. Now to go and open presents as the family is waking up. |
(Post 125502)
I've thought about getting mp template and porting it out hat way and do a 30° back cut in the valves. Any thoughts in that idea?
| All times are GMT -7. The time now is 03:46 AM. |
