5.7 hemp hard start in the heat and stall after refill
Old Aug 26, 2014 | 09:03 PM
A-Mac555's Avatar
04 Ram 1500 5.7 hemi. Hard start only after an hour or more in hot sun or after refueling. Plus after a refuel it stalls if you don't jump up the RPMs. It has a brand new fuel pump and on this model the fuel filter and pressure regulator are built into the pump. I have code that says small evap leak. I have no idea what is causing this. None of the injectors are visibly leaking but as you can see it acts as though it's flooded
The video is my truck
Old Aug 26, 2014 | 10:53 PM
Need to check fuel pressure. See how long it holds. Injectors can leak internally, they don't show it.... Also have the battery checked,,,
73landyacht
May 9, 2015 04:24 AM
69POLARA383
Feb 21, 2014 03:24 PM
mblackmon
May 17, 2012 12:12 PM
KaiGywer
Aug 4, 2009 01:31 PM
belvedere1965
Jul 2, 2009 08:58 AM
