906 heads/rocker shaft oiling
Should any thread locker be used on the bolts for the rocker shaft? I know it gets oil from shomewhere and not sure if that will block its path.
Thanks |
Just torque to specs.. NO thread locker required or needed
Ok but will it hurt anything if its already installed with it?
No it will be Ok !!
jst dont make it a habbit
the oil comes up through the bolt bores |
| All times are GMT -7. The time now is 06:48 AM. |
