aluminum head corroded stud
Old May 6, 2013 | 06:56 PM
Gorts 5th's Avatar
Smile aluminum head corroded stud
got a budi with a aluminium head, Nissan exterra his family car with a broken intake stud, broke off in it ...it's the typical corrosion you get when mixing metals like that .
his mechanic has, "probably not certified" has tried heating it reattaching a head on the bolt and it wont come out he's going to attempt to drill it out, but already dulled 2 carbide bit's. i'm trying to get pic's haven't seen it he's just trying to describe it to me,
what are your suggestions on how tow get it out
the head is on the motor it was pulled for a supposed head-gasket failure.
our tried and true was to heat the head or block with a propane torch, and hit the bolt with r 12, now today...134 a it works for us
how would you get it out?
Old May 6, 2013 | 07:36 PM
Better drill bits and a heli coil kit.
Old May 7, 2013 | 03:26 PM
PK1's Avatar
PK1
Yep... One works the drill, the other squirts the oil to keep it cool. Try going very small on the first bit and make a relief hole. Then walk the thickness in. As you get close to the threads try a dental pick and some times you can get the bolt thread out as pressure has been relieved by removing the inside diameter.
Dominic Torreto
Oct 11, 2012 09:10 AM
OHD
Apr 14, 2010 04:39 PM
jar84203
Jul 29, 2009 03:22 PM
nesparky
May 26, 2009 07:37 AM
Duster703404
Nov 16, 2008 06:00 PM
