Mopar Forums (/forums/)
-   -   Bad Fumes (https://moparforums.com/forums/f81/bad-fumes-19351/)
swilson68 Apr 17, 2016 05:37 PM
Bad Fumes
I bought a 71 Challenger which has a bad exhaust fume/odor in it only when the windows are rolled down. It is more of an exhaust odor than a raw gas smell and only occurs when either of the windows are down. I replaced the exhaust system (it needed one anyway) but the problem persists, it seems to come from the trunk area. I have also replaced the trunk seal and the trunk lid closes tight. It does have the emission vapour tube on the right wheel well in the trunk, but all the lines and hoses from the tank appear to be in good shape. The car is in good shape and does not have any holes in the floor. I am not sure what else to check.
Anyone have any ideas?
RacerHog Apr 18, 2016 08:59 AM
Make sure the exhaust tip are going out past the Valance panel out the back of the car.
swilson68 Apr 18, 2016 10:32 AM
1 Attachment(s)
Bob,
Thanks. My exhaust tips stick out about 1 inch past the valance panel.
Steve
RacerHog Apr 18, 2016 08:01 PM
Make sure all the breathers are hooked up in the engine compartment and the PCV valve is working good? That should handle under the hood...
My other suggestions..... Recheck the exhaust for any leaks in this case...
This next one might sound a little stupid..But just give it a try.. Take a couple pieces of cardboard, and make 2 - 6" longer tail pipe extension, tape it too the pipe ends and take for a short test drive... See if the smell goes away?
Keep us posted...
Will stay tuned.... :)
DDodger Apr 19, 2016 08:32 AM
Check for holes / rust under the car or anywhere in the rear body area. Get in the trunk on a bright sunny day with a helper and look for light. Have the helper move a bright lamp around under the car same thing.
What happens is the car creates a vacuum as it moves, and sucks exhaust gas up behind and under the car.
swilson68 Apr 19, 2016 10:04 AM
Bob,
Good points. The engine does not have a PCV. It has a breather on one side and an oil cap on the other. I will add a PCV and see if that helps.
I will try those fancy exhaust tips too. They are not patented are they? :)
Steve
swilson68 Apr 19, 2016 10:05 AM
DDodger,
Good way to check the trunk, I will give that a try.
Steve
Iowan Apr 19, 2016 11:19 AM
The bad fumes in my car are usually coming from me.:)
RacerHog Apr 19, 2016 07:10 PM
Hahahahahaah.... No Steve'o... Your good to go....Keep us posted..... :)
RacerHog Apr 19, 2016 07:14 PM
Can I have you stand over the induction system of my truck??, I could use some methane. Might get me too work a little faster....lol
:duck:
Iowan Apr 20, 2016 09:55 AM
Bob, just get some of those cool beans your allways promoting.:laugh:
RacerHog Apr 20, 2016 12:08 PM
Oh... Ya..... That's rite... Middle finger pointed...lol
Iowan Apr 20, 2016 12:27 PM
There ya go Bragging about your IQ!!!
