Mopar Forums (/forums/)
-   -   Can i install older LA oil pan on360 Magnium engine (https://moparforums.com/forums/f81/can-i-install-older-la-oil-pan-on360-magnium-engine-13231/)
fastcoauto Sep 9, 2012 09:39 AM
Hello Daryl here... still working on new 360 Magnium roller engine
Looked for after market pan eg Milodon ect... BIG $ on this budget engine.
Called round most supplier say you have to use a MAGNIUM oil pan / LA pan will not fit.
1 fellow told me a LA pan will fit this engine... BUT YOU MUST USE OLD 360 oil pan gasket set ... & then you can load LA pan onto Magnium block with this set up... apparantly there are differant oil pan gasket sets for LA engines.
Anyone done this pan swap... LA pan to new 360 Magnium engine?
Thanks to all in advance
PS: Got my water pump issue solved... older LA cover with LA pump
is on engine... THANKS TO ALL FOR THE ADVICE!
440roadrunner Sep 9, 2012 02:05 PM
I don't have first hand experience, but have been told that indeed a 360LA pan will fit a 5.2/ 5.9 Magnum. I'm not sure, though, which gasket you would need. I don't use the rubber seals on the ends of my LA engines anyway---just bet them incredibly clean and dry, and silicone them.
bremereric Sep 9, 2012 08:09 PM
You must use a 360 gasket on a 360. You must use a 360 oil pan on a 360. Mancini Racing has new 360 steel pans for your need.
fastcoauto Sep 11, 2012 09:22 AM
LA pan on
Hello all got L/A pan & 360 gaket set.... pan bolted up & sealed fine
rear seal perfect.... front seal had to trim prox 1/4 off bottom enf of seal to fit properly not sure why ... but it needed 1/4 off bottom.. anyway it sealed nicely now.... THANKS TO ALL for advice Regards Daryl
