can you tell what the compression is with this info?
VIN Codes
T,U,V Block Casting 2536430 Crank Casting 2206160 Head Casting 2406158 2843906 |
Nope, I can tell you better by what year the motor is. All I can tell you that it is a 1966-1972 440.
yep
thats all i am getting from the seller . no year just that range. should i any worrys about those head #'s?
The 906 head is good but I would ask the seller why it has two different heads on it. The 906 is good for compression.
