Mopar Forums (/forums/)
-   -   Carter AFB question (https://moparforums.com/forums/f81/carter-afb-question-13447/)
Shrug Oct 8, 2012 02:02 PM
Carter AFB question
OK, I just picked up a 1966 Dodge Dart wagon (will post pictures in a bit)
The car has a Carter AFB 8822. I do not see how to hook up a choke on the carb. If anyone know how this works, or better has a picture, please let me know.
Thanks!http://sphotos-a.xx.fbcdn.net/hphoto...88166043_n.jpg
bremereric Oct 8, 2012 02:50 PM
I would say you got you an aftermarket intake and there is no choke cup for the mechanical choke.
TVLynn Oct 8, 2012 03:26 PM
It is aftermarket.. I would guess you will need a manual choke. Or get the parts for an electric choke - hooks up to the lever by the black cap.
Check this picture http://www.ebay.com/itm/160897765614...84.m1555.l2649
Garys69RR Oct 8, 2012 06:15 PM
Appears to be missing some of the choke linkage, maybe take parts off an extra carb. Or a salvage one.
440roadrunner Oct 8, 2012 07:23 PM
I cannot tell for certain, but looking at the black tag, it appears to be an older Carter aftermarket AFB, they used to call their "competition series" before being bought out by Edelbrock. Those should be either manual choke, or have the black round thermostat like some of the older Ford/ Holleys used
Here's one with a manual choke, and the bracket to the rear is where the choke cable jacket clamps. That is, the clamp directly below the fuel inlet. What is the carb number, normally a 4 digit number followed by "S" stamped into one mounting ear on the front
http://www.74-77camaro.com/75camaro/...rterAFB-01.JPG
Below is one with electric choke
http://forums.aaca.org/attachments/f...05s-side01.jpg
Shrug Oct 8, 2012 08:23 PM
OK, it turns out I can get an electric choke kit. However I am missing part of the linkage on the other side.
This is the part I am missing:
http://sphotos-b.xx.fbcdn.net/hphoto...19939861_n.jpg
440roadrunner Oct 8, 2012 09:40 PM
That is your fast idle cam. I don't know if you can actually even get parts for them. Might be more trouble than it's worth, IE find another used carb, etc, or buy new and sell that one.
I ran my dart up here in N Idaho all through last winter on nice days, and started it OK sometimes down into the 20's F. I never used the choke at all, it's wired open
Garys69RR Oct 9, 2012 01:42 PM
My engine doesn't need a choke to start it either. Just 3 to 4 pumps, and she roars to life! Its a little flat for a few minutes, but then can drive it. Most perf carbs are prob on the rich side to begin with anyway.
