Distributor oil seal
Can anyone tell me if there is a seal or a O ring on the shaft of the distributor I have a 340 with electric ign. and I am getting oil coming out of it. All so I am looking for a set of spark wires that will fit the car all 8 cyl.
Yes, O,ring the groove is .110" wide and 1.820" diameter. Don't know a part number but with the dimensions you could source one before removal.
Between the dist housing and the roll pin there should be a metal washer IF not there ??? could be splashing too much oil on the dist shaft I don't remember seeing an actual seal other than the outer seal for the block
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:45 PM
robertoil
Jan 25, 2008 05:34 PM
