distributor problem! i need help
Old Aug 15, 2011 | 01:16 PM
shoreboy85's Avatar
i have put a 69, 383bb in my 82 dodge short bed, went to put the distributor in and it wont go all the way down? the gear it sits in is down and turns fine, but it still stays about a half inch up off the block, has anyone run into this problem?
Old Aug 15, 2011 | 01:49 PM
So you can see the distributor gear seated all the way into the gear on the end of the camshaft?
If so are you sure you have a big block distribuitor?
Old Aug 15, 2011 | 03:34 PM
JS23's Avatar
did it come out of that motor?
It sounds like you have a 440 distributor in a 383
The shaft is about 1/2" longer for the RB block.
Old Aug 15, 2011 | 04:16 PM
Bingo
Old Aug 15, 2011 | 05:08 PM
I have seen an adapter for that problem. I don't know where to send you to find it...
Old Aug 16, 2011 | 09:19 AM
shoreboy85's Avatar
yes the gear is all the way down, no it didnt comeout of this motor, but iv tried several ones my buddie had laying arround his shop and they all did the same. so now im on the hunt for the right one, thanks
Old Aug 17, 2011 | 12:31 AM
Here's the piece you need
http://www.summitracing.com/parts.aspx?sku=DCC-3690275
If you can find one ? I would try mother Mopar first
Old Aug 17, 2011 | 08:39 AM
Found this on the www
Mopar B engine – 3.5″
Mopar RB engine – 4″
MAKE SURE you don't have a small block dist. They rotate CW, B/ RB rotate CCW. To tell easily, just "spring" the rotor. You will have to "push" the spring the same direction it rotates.
On at least a few of these "laying about" can't you look up the dist. number to find out?
The thing is, the gear might be "all the way down," but you might NOT have the bushing all the way down
JS23
Dec 17, 2014 10:13 AM
newto440
Apr 13, 2014 09:45 AM
ottosen@chorus.net
Aug 10, 2013 05:46 PM
Ty Henry
May 24, 2012 06:15 PM
Aspen
Aug 31, 2009 10:25 PM
