distributor problem! i need help
i have put a 69, 383bb in my 82 dodge short bed, went to put the distributor in and it wont go all the way down? the gear it sits in is down and turns fine, but it still stays about a half inch up off the block, has anyone run into this problem?
So you can see the distributor gear seated all the way into the gear on the end of the camshaft?
If so are you sure you have a big block distribuitor? |
did it come out of that motor?
It sounds like you have a 440 distributor in a 383
The shaft is about 1/2" longer for the RB block. |
Originally Posted by JS23
(Post 73383)
I have seen an adapter for that problem. I don't know where to send you to find it...
yes the gear is all the way down, no it didnt comeout of this motor, but iv tried several ones my buddie had laying arround his shop and they all did the same. so now im on the hunt for the right one, thanks
Here's the piece you need
http://www.summitracing.com/parts.aspx?sku=DCC-3690275 If you can find one ? I would try mother Mopar first |
Found this on the www
Mopar B engine – 3.5″ Mopar RB engine – 4″ MAKE SURE you don't have a small block dist. They rotate CW, B/ RB rotate CCW. To tell easily, just "spring" the rotor. You will have to "push" the spring the same direction it rotates. On at least a few of these "laying about" can't you look up the dist. number to find out? The thing is, the gear might be "all the way down," but you might NOT have the bushing all the way down |
| All times are GMT -7. The time now is 06:27 AM. |
