Mopar Forums (/forums/)
-   -   dual quad intake manifold help!! (https://moparforums.com/forums/f81/dual-quad-intake-manifold-help-10129/)
71 scamp Jul 16, 2011 01:31 AM
Im wanting to buy a dual quad intake manifold for a 360 engine. Ive been searching around and can only seem to find them for engines above a 396. any help in locating an intake manifold that would fit is appreciated. As a side note a smarty pants on yahoo answers said in order to do this all i have to do is
"You'll need a "dual quad" intake manifold. Install that. Bolt the carbs up to it. Add a "T" fitting to the fuel line, with a little extra line to feed the extra carb. Replace the throttle cable (or rod) with a multiple carb setup. You may need to replace the fuel pump to up the pressure a little."
anything he's missing?
i was told the engine produces around 300 hp with a 4 barrel (im sure its more like 275), any guess to what it'll do with the dual quad set up?
thanks
Archer Jul 16, 2011 07:10 AM
71 -
Try Summit.
http://www.summitracing.com/parts/OF...n/?prefilter=1
This one is for a 318, and "should" fit a 360, but check first.
Your other options are a 6V (3x 2V) or a tunnel ram.
Also, if your engine is running correctly with a single 4V, going to 8V may look cool, but you'll probably LOSE efficiency.
The reader's digest instruction are basically correct - getting it to work, may be another story...
440roadrunner Jul 16, 2011 08:01 AM
Unless you have a VERY aggressive race engine with big ports, valves, cam, etc, you MAY NOT get any more power or possibly EVEN LESS power from what you are calling a "dual quad" manifold over a WELL CHOSEN performance single carb manifold and carb.
You need to take a look at YOUR engine presently, what if anything you are going to change in the way of heads, cam, headers, exhaust, and take a REALISTIC view of it's RPM range, and go from there
WHAT are you running now for intake/ carb?
Frankly, on most mild street engines, it would be hard to beat the factory performance 340/360 4bbl manifold. The Edelbrock "performer" manifold is probably the closest thing to the factory manifold you can buy.
The mis -named Edelbrock "Torker" is not really a "torque" building manifold at all, but rather FAIRLY high RPM --it is completely wrong, for example, to put a Torker on a trailer towing rig where torque is exactly what you want.
The fact is, the old school "in line" dual quad manifolds are a thing of the past. Back before we had 700-900 cfm single four carbs, a pair of what was then available was one of the few ways to "get more."
Coronet 500 Jul 16, 2011 10:03 AM
Lots of good single 4 manifolds and carbs to do what ever you want. 2X4's have the cool look. Have a look here. http://www.indyheads.com/modman.html .
They have a good tech article on their open plenum design.
That Offenhauser has a nice heat well and crossover for choke operation, which is a plus for a street car. A couple of small vacum secondary carbs could be driveable and a lot of fun. The 6 pack is alot of CFM and can be tuned to do just about anything you want.
Edit: My good pal has a couple really small 4's on his 61 Impala 283, it's a riot to drive and stupid cool when you raise the hood.
MercuryDon Jul 16, 2011 01:39 PM
Go with the six pack as its easier to tune.
71 scamp Jul 16, 2011 04:44 PM
thanks for the help and quick answers, based on your responses it seems like getting a dual quad set up isnt going to help very much the way the engine sits now, except in the looks department. so i guess ill look more into cylinder heads and possible the 6 pack.
Thanks again
