Mopar Forums (/forums/)
-   -   Edelbrock Aluminum Heads - Angled Valve Cover Bolt Holes?? (https://moparforums.com/forums/f81/edelbrock-aluminum-heads-angled-valve-cover-bolt-holes-17227/)
hckrphil May 7, 2014 08:09 PM
Hi Everyone!
New member here!!! I'm currently building a 1934 Dodge, fully custom street rod....
Check it out here: http://34dodge.blogspot.com/
My engine is currently at the motor shop....a mopar 440 big block.. It is being completely rebuilt, bored .030, engle cam, Edlebrock aluminum heads, harland sharp roller rockers, edlebrock aluminum intake, quickfuel hd780 carb.
Everything has been assembled on the engine and its sitting on the dyno. As we go to bolt on the valve covers, we found out ALL the valve cover holes in the head are at a slight angle.... has anyone else seen this?
At this point, we're too far along to tear it all apart again and try to re-drill all the holes.... we're going to try some threaded rod in the holes, and then hammered straight... worth a shot.
Thanks everyone!
~Philcash
hckrphil May 7, 2014 08:36 PM
5 Attachment(s)
If I'm gonna talk about it, I might as well show it off a little :)
Attachment 8821
Attachment 8822
Attachment 8823
Attachment 8824
Attachment 8825
Mr.4spd May 8, 2014 03:17 AM
The valve guides and seats were all over the map on mine, had them blueprinted and they're great now. Nice car btw.
RacerHog May 8, 2014 06:20 AM
Welcome to the site Phil.....
Cant say I have had the Valve cover bolt problem... That's a odd one!!
But like Mr. 4speed said... I have had to have all there heads gone threw to have the valve stem height corrected..... But other than that... They work great for there intended use....
Love those old 41 Dodges...... Just an FYI... I just seen a ProMod Body of a 41..Soo Cool.. :)
http://fastdoorslammers.com/forums/s...ad.php?t=15112
TVLynn May 8, 2014 09:51 AM
Every one should complain to Edelbrock about their quality control
hckrphil May 8, 2014 11:41 AM
1 Attachment(s)
Here is the crooked vent cover bolt.......... tapping them with a hammer to straighten them out works perfectly fine........ just cheezey this passed quality control?
They are all angled the same way, on both heads!
I put a red squared on it so you can see how much they are off!!!!!
Attachment 8830
Mr.4spd May 8, 2014 01:08 PM
Attachment 8830
Looks like your valley pan spread bars are missing.
hckrphil May 10, 2014 07:00 PM
You are correct! Good eye! I have to find a pair....
Phil
hckrphil May 10, 2014 07:06 PM
Motor is finally home!!!! Pulled 485HP with 500ft/lbs of torque!!! I'm extremely happy being I was shooting for 400HP :)
Bolting the motor / tranny together and dropping it in the car tomorrow :)
~Phil
pro-tech May 11, 2014 06:30 AM
:look::welcome2:Very nice car and looks like a lot of work & money...But all these cars cost a ton of money cashcashLove the color... Hope it all goes well with the rest of your build...I would call Edlebrock and tell them about the V/C bolt holes,, maybe there jig is off and needs to be corrected... And maybe they will send you a perk for bringing it to there attention...Cant hurt right...Bill
RacerHog May 11, 2014 06:45 AM
Nice.. :)
