Engine Bogging and backfiring at speed
Old May 16, 2015 | 03:29 PM
Austringer's Avatar
I have a 1969 Dodge 361 wedge head with a 670 cfm Holley Truck avenger carb on ot. My issue is as follows. Driving it today, it would randomly start bogging down backfiring one and a while and almost die, unless I either shifted up or down a gear. At one point, I could only go 30-35 mph and thought the engine was about to cut out completely. If I give it full throttle, it does bog way way down and will start backfiring. It did this once before about 3 weeks ago, same exact systems. I thought the carb had some dirt int it or something else. The carb is only a few months. When it started last time, I removed the carb (PIA in this vehicle) and took the end covers off and it looked fine, I blew the jets out as well to make sure they were clear. The thing I did notice was a fairly thick brown lacquer on the bottom of the carb and just inside the intake manifold. I used a spray carb clear to remove it and it came right off, but now I'm havering similar issues again. When I had the carb out last time, I put a inline fuel filter in as well. What causes the brown lacquer deposits to be all over the underside of the carb. amd frp, , memory, the secondary was sticking or wass stuck closed because of this. Once I had the carb completely cleaned, it worked great and I drove it about 20-430 milses, put it up and then drove it to ta show about 5 miles from the house and on the way back, it started doing it again. What causes the laqucer to build on the bottom of the carb? What can i do to prevent it. Right now I'm going to spray the inside of the carb's secondaries and then go for a drive and see what it does.
Thanks for your time and assistance with thes>
Old May 16, 2015 | 04:54 PM
Welcome. I would think old contaminated tank and lines.
Old May 16, 2015 | 10:26 PM
Drag Pak's Avatar
Old May 17, 2015 | 02:49 PM
old gas ! Clean the fuel system/tank , replace any rubber hoses..
norcalitwin26
Jun 5, 2014 02:16 PM
sysheler
51
May 15, 2014 12:52 AM
JJokr990
Mar 3, 2010 08:49 AM
bc18
Jul 22, 2009 04:16 PM
joel
Feb 22, 2009 07:07 PM
