exuast manifold water?
Old Aug 4, 2011 | 10:49 PM
auerdoan's Avatar
do i say oh no or oh
i was wanting to replace the gasket behind my exhuast manifold
so l started to back out one of the bolts and hmm water the color of my water coolent. if its normal no problem i drain it.
but if its not oh nooo.
so maybe someone can tell me is this normal a co worker says its impossible 4 there to b water
http://electricriver.50megs.com/truck.htm
picture of manifold & bolt
Thanks in advance for ur help
Old Aug 4, 2011 | 11:50 PM
It is normal !! Several of the exhaust studs screw into the water jacket...
Old Aug 5, 2011 | 05:53 AM
fivepoint's Avatar
It is normal. Before you install the bolts be sure to clean the threads and apply a sealant to them.
Old Aug 5, 2011 | 06:51 AM
kiwi's Avatar
yea i found the same thing with my RR but i was under it replacing the starter when my mate undone the bolt so got a nice mouthful of coolant good times!
Old Aug 5, 2011 | 07:27 AM
auerdoan's Avatar
this site has once again proven itself
thanks guys
Old Aug 5, 2011 | 06:31 PM
scotts74birds's Avatar
Wait....We're not done yet! Now ask what is best to seal those bolts with! [kinda like arguing fishing lures!] I use Loctite 567. A pipe sealant recommended to me by the pipefitters at work, never a problem.
Old Aug 8, 2011 | 12:58 PM
auerdoan's Avatar
your correct i was debating this in my head over the weekend and saw your post today
i was going to use the same stuff i used for my gasoline inlets on my carb.
i dont remember the number its lock tight but its reacts when it sniffs out metal surroundings
i think the carb has a diff temp than the exhaust mani so i may be back to use your recommended...
thanks for the post
Old Jan 16, 2012 | 12:01 PM
moparted's Avatar
no sealant on fuel lines
Achan
Jul 17, 2009 07:34 PM
M1 Manifold
May 21, 2009 02:23 PM
Chall70
Sep 23, 2008 07:39 AM
rocketken
May 20, 2008 05:52 PM
super commando
Mar 25, 2008 03:12 PM
