Mopar Forums (/forums/)
-   -   Fuel in a Jug Question? (https://moparforums.com/forums/f81/fuel-jug-question-18064/)
Robert Weaver Nov 18, 2014 08:31 AM
Hello,
Right now I'm running my charger with a gas jug due to tank bein off and wanted to know if I could add fuel cleaner to the gas jug? Would it hurt the carb?
RacerHog Nov 18, 2014 02:31 PM
I don't think so.... Just use the rite mix..
Robert Weaver Nov 18, 2014 02:34 PM
Any preference on cleaner?
moe7404 Nov 18, 2014 03:36 PM
are you saying you have a loose jar rattling around with gasoline in it? hope not. or do you have death wish? maybe you need professorial help.
Robert Weaver Nov 18, 2014 06:14 PM
Ha ha ha, no I've got a gas jug on the ground with a hose goin to the pump. Not rattlin around.
moe7404 Nov 18, 2014 06:48 PM
yep you are on top of it. you DO have a fire extinguisher dont you? i think in Kansas has a reg that at the gas station the gas can must be on the ground to fill it up. no explanation needed.
RacerHog Nov 18, 2014 07:02 PM
Lucas Fuel Additive....
Robert Weaver Nov 18, 2014 07:04 PM
Thanks again for the help. Just out of curiosity, what would a used Poly 318 motor thats been Top End Rebuilt go for?
RacerHog Nov 18, 2014 07:11 PM
I wouldn't bother... I would just move straight over to an LA Long block...
Robert Weaver Nov 18, 2014 08:52 PM
K, which size engines will fit the 74 b bodies? Any Small/long block?
RacerHog Nov 19, 2014 08:28 PM
Any of the 70's 318 will fit.... Better if you get it complete... That way you have most all you need...
Here are a few places to look....
http://www.car-part.com/dealersaz.shtml
