fuel mileage questions on 318?
Old Aug 30, 2011 | 05:33 PM
redneck9507's Avatar
I have a 1971 D100 just a plain old automatic farm truck with no upgrades. I have recently started looking into the holley 2d fuel injection systems. Does anyone know what the fuel mileage gain would be with this 2 barrel fuel injection system? Also Are there any other ways to get better fuel mileage. I am looking for cheap ways although I do have money to spend.
please let me know
Zach
Old Aug 30, 2011 | 06:39 PM
A gear change would get a mileage gain. Do you know what ratio the truck has?
Old Aug 30, 2011 | 06:43 PM
The one I have now Has 355 gearing with a 4 speed hemi overdrive transmission. So I think that's good with the tires I have.
Old Aug 30, 2011 | 06:56 PM
Agree. I have no experience with the holley system. A well tuned carb engine with no emissions should get decent fuel mileage.
Old Aug 30, 2011 | 07:48 PM
Ok it's an auto ? You might get 2 mpg better, maybe ! For the expense you can buy a lot of gas !!! A change to a 3.23 gear set in the rear would do more for mileage. A D100 I would guess has a 8 3/4 differential, easy to change..
Old Aug 31, 2011 | 08:49 AM
Let's start with what you are getting NOW?
How heavy is your foot, realistically?
What sort of roads do you drive?
Do you actually drive a LOT on the highway, or mostly secondary roads?
In other words, for the condition of the vehicle, the roads and the way you drive, you might already "be there."
YOU WILL NEVER pay for converting to fuel injection, if you drive that truck another 20 years.
Old Aug 31, 2011 | 02:47 PM
Well when I am out messing around I will get on it but when I am driving it I can keep a light foot. Seems like the fuel injection would pay it self back almost within a year.
Old Aug 31, 2011 | 02:56 PM
Oh and the first question, I never figured for myself but the one with the 4 speed and 355 gearing My dad claims 13. That is with a 650 carb as well. It also has 360 heads. I think the 360 heads help the fuel mileage because it lowers the compression and flows more.
Old Aug 31, 2011 | 03:42 PM
I don't want to rain all over your parade but the 360 heads could be decreasing your fuel mileage. The key to these smaller engines with stock or close to stock cams is port velocity. This is what will increase low end power and increase fuel mileage. If you were to put on a set of late 80's 302 swirl port heads, even with smaller ports than the 360's, you'd see a significant improvement.
I tried the 360 on 318 years ago and it was a mutt until it got spinning above 3000 rpm.
Old Aug 31, 2011 | 06:39 PM
89ram150's Avatar
My '89 gets around 14-15 when I drive it the way I should. 10-11 when I drive it like a stolen hemi cuda. Alot of the TBI guys are always swapping for carbs. If you got a donor vehicle or someone that wanted to do a full swap, that might be the cheapest way to get EFI. If you're keeping the 318 stock or close to it, might be an option worth looking into. My $.02. My TBI seems to run a little on the rich side, so I've actually been considering swapping to a Carter 2 barrel setup off of a '71 Satellite (because it's free).
rcknrolfender79
Mar 14, 2020 05:45 AM
jcloving
Jun 6, 2011 03:47 PM
bremereric
Mar 13, 2011 10:58 PM
hipowerv10
Oct 22, 2010 03:33 AM
CantRamItDodgeIt91
Aug 28, 2009 08:20 AM
