Head question (casting numbers etc)
2 Attachment(s)
Really bad at this kind of thing with casting numbers, I have been trying to figure them out for years and can NEVER match my stuff up with the charts found online.
Attachment 18865 (4027596) Attachment 18866 came off of a motor that was in a 77 powerwagon. Thank you in advance. |
They came on 77 to 80 something 360's and some say HP 318's. They are not the swirl port or closed chambered heads but there was alot of back and forth arguements about them. Most said put some larger valves in them, port them some and you will have a good head. Note the smog holes. I had them on some cast 308 heads. Drilled them and tapped them and installed a set screw to block them off.
they worth anything? I am new to the Mopar world and and parting out the drivetrain of a truck I have. IE, motor, transmision.
if their from a 360 they will have 1.88 and 1.60 valves. 318 heads have 1.78 and 1.50.
Originally Posted by 78doubleR
(Post 80190)
| All times are GMT -7. The time now is 08:22 AM. |
