Which heads
Which heads
I have a 74 440 that I am going to put into my 67 belvedere. My question is that I have a set of 69 906 heads off a Polara cop car I know the valve seats aren't hardened but I talked with a local Engine Builder and he said unless I plan on driving it every day it probably won't matter much. My question is if these heads will make that big of a difference compared to the stock heads on the 440 now.Thanks,
Tony
Tony
heads
what are your intentions for the car?
my 71' had 346's on it i believe, low compression low flow smog heads.
guessing you have the same on the 74 block.
cant go wrong with the trusty 906's if your not going to go aluminum.
they can be ported to flow pretty nicely.
906
Here is my two cents: Rebuild the 906's - shave them to what is within spec and put them on. When using a head gasket, you can select a thinner metal version. Between the better air flow and shaving, you will get a bit of better compression. Your 346's are a good head as well, both are open chamber with the same valve size. rebuild and shaving is about 500 +/- some. so take that into consideration.
7T_ChargerBlues
Feb 29, 2012 09:06 PM
