high oil pressure
hey guys,just noticed my oil pressure at 75 while at hiway speed.drops to 25 at idle.its a 512 stroker motor.is thi normal?
if not what do you think the problem could be other than the gauge? |
What pump do you have? And what is your idle speed?
75psi is ok running down the road.... 25PSI at Idle is a little low for my liking. I like to see them at about 30PSI at idle. However, it's not horrible if that's what your asking....
Mine runs 30 - 35 at idle.
high oil pressure
hey guys,thanks for the info.just bought this car on ebay,so just trying to learn about the motor
my first performance mopar and am loving it. |
1 QUESTION.... How many quarts oil pan is on the engine?
high oil pressure
it has a 7 qt.pan and on a closer look oil pressure at idle is around 30.thanks for your help
Sounds good.. Have fun !!! :)
| All times are GMT -7. The time now is 12:25 AM. |
