Mopar Forums (/forums/)
-   -   Intake manifold air sound (https://moparforums.com/forums/f81/intake-manifold-air-sound-19193/)
josehf34 Feb 19, 2016 11:52 AM
My car has a 360 SB, I cleaned the engine yesterday and just after finish and start the car, I heard a sound like air leak coming from somewhere around the intake manifold.
I already checked and the sound isn't coming from the carburetor air horn, also, the vacuum gauge shows a decrease in the vacuum signal at idle
I made a video where can hear the sound
Link: http://vid1067.photobucket.com/album...pshafgtjbv.mp4
Archer Feb 19, 2016 02:20 PM
j -
Well you have a vacuum leak, no surprise there. Take a squirt bottle full of water and spray around where you hear the noise. When the noise changes, you found your leak. Do all the gaskets, connections, etc.
Iowan Feb 19, 2016 02:48 PM
Or break cleaner ,carb cleaner.
fivepoint Feb 20, 2016 09:25 PM
While you were cleaning, did you disconnect or break a vacuum hose?
fivepoint Feb 20, 2016 09:34 PM
just watched the video, is your fuel line ok? Looked like it had kink in it.
Iowan Feb 21, 2016 08:52 AM
It should be replaced with a steel line.
DDodger Feb 24, 2016 08:26 AM
Get a scrap of hose, fuel hose, garden hose, "hose hose". Put up to your ear, and work the end around the manifold and carb while running. You will find it. There's a leak, there, somewhere
josehf34 Mar 1, 2016 04:37 PM
Thanks guys!
I did a quick rebuild and inspection, replaced intake, exhaust, heads gaskets and the sound disappeared
Iowan Mar 1, 2016 07:24 PM
It's nice when things work out!
