Mopar Forums (/forums/)
-   -   Lean burn conversion (https://moparforums.com/forums/f81/lean-burn-conversion-15593/)
chykov's76doba Aug 14, 2013 07:56 PM
I am thinking about converting the lean burn system in my 76 Cordoba 400 4bbl. Any advice on what conversion kit to use would be helpful. Also, can I use the stock carburetor? If not, any advice would be great.
Thanks in advance for your help.
TVLynn Aug 15, 2013 03:58 AM
Main thing is to replace the ign module and the dist. You can use stock parts, MSD all in one dist, several choices
http://www.ebay.com/itm/BB-MOPAR-RED...d5e110&vxp=mtr
moe7404 Aug 15, 2013 01:27 PM
i have used the chtysler kit that went good. hint: 1 if the cap has a air vent. plug it with JB-weld. 2: get two extra ballast resistors, put them in the glove box. when the first fail to start happens. get one ballast out and replace the one on the fire wall
