Mopar Forums (/forums/)
-   -   lifter question (https://moparforums.com/forums/f81/lifter-question-11316/)
lifted150 Dec 25, 2011 08:08 PM
lifter question
ok so i pulled my valve covers an a few lifters were a little lose motor is a 318, so i thought ok maybe a push rod is bent so i pull the intake, pull the push rods, install a new set an tighten them to factory specs an i can still move a few of the lifters side to side a bit is this normal??? the truck ran great, did not tick, bang ect ect.... also do you got to tighten them when you turn them motor over as well??? i thought i heard i was supposed to but cant remember
TVLynn Dec 25, 2011 10:03 PM
Assuming it is a stock LA 318 motor. The rockers are shaft mounted and non adjustable. The shaft bolts should be tightened to 25-30 ft lbs ???? Look it up... Lifters are pumped up with oil preassure to take up the clearance.. Without oil pressure the lifter may be loose It depends on how fast the lifter bleeds down
lifted150 Dec 25, 2011 10:37 PM
Originally Posted by TVLynn (Post 79608)
Assuming it is a stock LA 318 motor. The rockers are shaft mounted and non adjustable. The shaft bolts should be tightened to 25-30 ft lbs ???? Look it up... Lifters are pumped up with oil pressure to take up the clearance.. Without oil pressure the lifter may be loose It depends on how fast the lifter bleeds down
ya i tightened them to to the right specs, so i shoucl be good right?? i for got to add that oil is pumped an tightens them up lol, do i re tighten the pushrods after i turn it over or no??
blue 68 gts Dec 26, 2011 11:27 AM
Theres no valve adjustment, put the rocker shaft on, torque them down and go.
lifted150 Dec 26, 2011 06:23 PM
ok thanks ya thats what i thought, ya guys did it again :clap:
