Low RPM Hesitation
Old Nov 15, 2023 | 03:06 PM
jsh's Avatar
jsh
Low RPM Hesitation
Sooooo, I have a 1976 Dodbe D200 Truck. I acquired the truck in a trade. the truck has a hesitation on low rpm other than that it runs great. New fuel, timing is correct, carb has been adjusted, grounds are good. Have adjusted the excelerator pump many times and many positions, no change. Truck has a knock off mid rise manifold have no clue who the manufacturer is. Also have knock off Edlebrock 1406 made bye Geluoxi.. Very nice amazon piece LOL. The distributor is also avery nice knock off, this one is also a nice amazon piece, MAS Performance HEI Distributor Replacement for Mopar. I have to feather the pedal off of lights and it wants to hesitate on transmission shifts or when im cruising down the road at low RPM and give a healthy dose of fuel. The fuel filter also looks like it is about ready to explode after the 20 minute drives. I really dont want to throw a lot of money at the truck. Im going to sell it as soon as I get it running correctly.
Old Nov 15, 2023 | 03:41 PM
Lostviking's Avatar
HEI crap isn't adjusting the advance properly for the change in load?
Old Nov 16, 2023 | 04:26 AM
jsh's Avatar
jsh
Thanks I will check that out today
Old Nov 16, 2023 | 04:39 AM
Kuvasz101's Avatar
Total timing should be upwards of 32-34 degrees @ 2500 rpms. You have the accelerator pump set at max flow on the bottom hole which is best for heavy accelerations. Those accelerator pumps go bad quite easily from the ethanol
fuel. Look down the carb and give it a slow throttle push and see if the pump shoots out a steady flow of fuel. I bought an accelerator pump recently, installed it and ran great. It didn't take long for it to act up again due to the ethanol gas. Here's a good site to buy a pump for your carb. Carburetor AFB 4-barrel Accelerator Pumps (carburetor-parts.com) Good luck!!
Old Nov 17, 2023 | 04:40 PM
jsh's Avatar
jsh
Thanks everybody for all the ideas I will try to get to those this weekend. I will keep you up-to-date.
Jimmybaps
Mar 16, 2023 01:13 PM
TomKansasCity
19
May 24, 2019 08:00 AM
BigYellow
24
May 6, 2014 07:17 PM
Grace87Ram
Nov 4, 2013 08:39 AM
petree1
Jan 21, 2008 09:17 PM
